17249 Discussions
Why are partitions not supported anymore?
DBay
It used to be that you could have multiple levels of partitions and LL regions. Now with the latest software, you can no longer do anything but a flat design as Quartus 18 will crash or see conflicting assignments when there are none. Usually it just crashes. If partitions are no longer a supported function, then please remove it from the menu options.
KhaiChein_Y_Intel
Design Partition and Logic Lock are supported in the Intel Quartus Prime software.
(Reference: https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/download.html).
Kindly contact your FAE/Intel Sales representation to submit a service request to Intel Support Team for Crash/Internal error debugging.
KhaiChein_Y_Intel
Could you send the design for investigation?
DBay
No, it is ITAR/military. You don't support that code.
LL regions are also not supported in pro for import/export. At least no one appears to know how to do it.
WHen you use standard, it just crashes. So, it may be documented, but still unusable.
