17267 Discussions
Why doesn't Quartus recognize my license?
LLars
SAR
Hi
What licensing problems are you facing?
Problem may be because
1. License may be expired.
2. May be Licenses setup issues.
3. Update the Quartus version and license file not updated.
Depending on when your license file expires, you may need a new license file to use the new version of the software
1. Which license(Fixed license or Floating license) you have used?
 If you use Fixed license ->Regenerate the license and try.
 If you use Floating license ->Check the environment variables.
https://www.intel.com/content/www/us/en/programmable/documentation/esc1425946071433.html#esc1426013042774
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/ts-index/lic.html?fn=lic#intel_quartus_development_software
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/licensing.html
If it does not solves the problem.
You can contact the FAE or raise a ticket
https://fpgasupport.intel.com/AlteraLicensing/license/contact.html
Devil
LLars
License is not expired.
License works when I use Quartus 17
Fails when I use Quartus 16.1
License path is setup to point to the file
AnandRaj_S_Intel
As suggested you can
or
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
