17268 Discussions
Why index cannot fall outside?
The following is my code for nixie tube's driving.
At line"$" their is an error clew"Error (10251): Verilog HDL error at MyDAQCard.v(120): index 15 cannot fall outside the declared range [7:0] for dimension 0 of array "CST"".
My cst_reg.txt contents:
100110001001011010000000 11110100001001000000
000000011000011010100000 00000010011100010000
000000000000001111101000 00000000000001100100
000000000000000000001010 00000000000000000001
I want know why j>=0 is wrong at verilog?Thanks a lot.
reg [3:0] dataout_memo[7:0];
reg [31:0] CST[7:0];
reg [3:0] i,j;
reg [31:0]data_reg;
reg flag;
always @(posedge clk)
begin
data_reg = data_in;
$readmemb("cst_reg.txt",CST);
for(j=7;j>=0;j=j-1) //" $$$$$$$$$$$$$$$$$$$$$$"
for(i=1,flag=0;i<=9;i=i+1)
if(data_reg>=CST[j])
begin
data_reg = data_reg - CST[j];
dataout_memo[j] = i;
flag = 1;
end
else if(!flag)dataout_memo[j]=0;
dataout_memo[0] = data_reg; // handle:j=0 "@@@@@@"
data_reg = 1'b0;
end
--- Quote Start ---
--- Quote End ---
It's not wrong with Verilog. But loop evaluation fails according to your signal definition reg [3:0] i,j; Verilog numbers are unsigned by default, so j>=0 is always true. Iteration schemes are evaluated at compile time, there is no need to define loop variables as bit vectors. Use an integer type instead.
Assigning dataout_memo in a loop prevents it's implementation as internal RAM. I'm not sure if this is what you intend.
Thank you dude. It's a new error if "i,j" are integers.:"Error (10249): Verilog HDL Declaration error at MyDAQCard.v(107): objects with integer type cannot be declared with a range".
How to clear that? I tried my "for" loops at vc++environment, j>=0 is right,and line "@@@"is no need to write at vc++ . &#65307;&#65289;
i need that dataout_memo[0]( j=0) as the unit data on nixie tube.
Can u help me to handle this ?
for(j=7;j>=0;j=j-1) // $$$$$
begin
flag = 1;
end
dataout_memo[0] = data_reg; // @@@@
data_reg = 1'b0;
Thank you!
I don't see an integer declaration with a range in your last post (there are no declarations at all). I also don't know why it should be needed. Generally, if reporting any compilation errors, it would be a good idea to mark the line of error.
