Dear all,
Recently I've install Matlab R2008a and Quartus2 9.0, DSP builder 9.0. But there is no DSP ip library in simulink. I've tried search the internet and read the manual, including this thread http://www.altera.com/support/ip/dsp/ips-dsp-builder-faq.html#q_16, still I can't fix it. What should I do to make them work??Link Copied
No advice?:(
to resolve this problem you must type the following command in matlab:
cd <directory>\DSPBuilder\Altlib; setup_dspbuilder;- Mark as New
Hello I have exactly the sale problem but I don't have the Altlib in the directory that you specify.
Could you help me ?- Mark as New
Probably the reason no one replied, is that there is a specific DSP Builder forum at dsp builder and dsp ips (http://www.alteraforum.com/forum/forumdisplay.php?f=34). DSP Builder experts may not read the general quartus forum.
bouzied007's advice unfortunately has not been valid since DSP Builder 7.0. For 9.0, the advice at http://www.alteraforum.com/forum/showthread.php?t=22876 (http://www.alteraforum.com/forum/showthread.php?t=22876) should work.
