17268 Discussions
Why the warnings and critical warnings disappear when I open the project again ?
If I compile a design, after it finished, in most cases I will have some warnings and critical warnings in the message windows. I need to skim them to see whether they indicate some serious issues.
But I found a problem that, if I close the project, and reopen it, these warnings and critical warnings disappear. Why? Is there approach I can keep them or I can make them appear again?
Near each step in the compile process there is a button saying 'View Report'. If you double click on one of those it will show you the project summary which includes a list of all messages the compiler generated.
You can also view them in the .rpt files generated with each step of the compilation.
Cheers,
Alex
Thanks both of you very much.
