If I compile a design, after it finished, in most cases I will have some warnings and critical warnings in the message windows. I need to skim them to see whether they indicate some serious issues.
But I found a problem that, if I close the project, and reopen it, these warnings and critical warnings disappear. Why? Is there approach I can keep them or I can make them appear again? Thanks.Link Copied
Near each step in the compile process there is a button saying 'View Report'. If you double click on one of those it will show you the project summary which includes a list of all messages the compiler generated.
You can also view them in the .rpt files generated with each step of the compilation.
Cheers, Alex- Mark as New
Thanks both of you very much.
