17267 Discussions
Why there is no device model for EPM1270GM256 in quartus?
I am going to use the CPLD EPM1270GM256, but I cannot find EPM1270GM256 device in quartus.There is EPM1270M256,but not EPM1270GM256.How to solve this problem?
Wishing for your help!!Thank you
See "are the programmer object files (.pof) for max® ii and max® iig devices compatible? (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd12212005_320.html)".
In short, you've found the right part. There aren't any MAX IIG devices available to select from in Quartus. You need to choose the EPM1270M256 part you've found.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
Thank you for your reply!
