17252 Discussions
Windows/Linux SignalTap not recognized
We are experiencing a problem with Quartus 9.1 and SIgnalTap. I've search the forum and found nothing similar.
When we do SignalTap plus place&route on our 64-bits linux server, the generated assembler file works fine in the programmer on a Windows machine and the design is functional. But SignalTap is not recognizing his target like when you put a incoherent programming file and signaltap definition.
It seems there is something wrong between a SignalTap fit generated on a 64-bits Linux and SignalTap on a 32-bits Windows PC.
Have you experienced such a thing ?
EME
--- Quote Start ---
EME
--- Quote End ---
what kind of error message did you get ?
Kind regards
GPK
No specific error message. I get just the red thing telling you to reprogram the chip.
EME
--- Quote Start ---
EME
--- Quote End ---
maybe it sounds stupid, but are you sure that you use the newest stp-file ? Are the Linux and Windows versions really identical ? If yes, I would recommend to run a small testcase and check whether it behaves the same.
Kind regards
GPK
