17255 Discussions
Writing data to output file VHDL
Hi all,
I'm working with a DE2 Altera board Quartus II 6.1 and am trying to take data that I receive from the board, and send it to an output file, a text file.
There will be a lot of data so I don't want to use the output LEDs or LCD. I found this simple code online, but it will not compile on my machine b/c I get the following error:
Error (10481): VHDL Use Clause error at printing.vhd(5): design library "IEEE" does not contain primary unit "std_logic_textio"
Does anyone know how I can perform a simple output to file????
library STD; -- you don't need STD, it is automatic
library IEEE; -- but may need other libraries
use IEEE.std_logic_1164.all; -- basic logic types
use STD.textio.all; -- basic I/O
use IEEE.std_logic_textio.all; -- I/O for logic types
ENTITY printing IS
port (
abc :in std_logic
END printing;
architecture test of printing is -- where declarations are placed
subtype word_32 is std_logic_vector(31 downto 0); -- simple name
signal four_32 : word_32 := x"00000004"; -- just four in hex
signal counter : integer := 1; -- initialized counter
begin -- where parallel code is placed
my_print : process is -- a process is parallel
variable my_line : line; -- type 'line' comes from textio
begin
write(my_line, string'("Hello World")); -- formatting
writeline(output, my_line); -- write to "output"
write(my_line, string'("four_32 = ")); -- formatting
hwrite(my_line, four_32); -- format type std_logic_vector as hex
write(my_line, string'(" counter= "));
write(my_line, counter); -- format 'counter' as integer
write(my_line, string'(" at time "));
write(my_line, now); -- format time
writeline(output, my_line); -- write to display
wait;
end process my_print;
end architecture test;
-- compile/analyze this file
Paul
You are mentioning a DE2 Altera board. Are you trying to do this on hardware or is it a test bench simulation?
What simulator are you using? I know that the ieee.std_logic_textio package is included i ModelSim. I don't know about NCsim and simulation inside Quartus. You might need to install/map additional libraries and packages.
For hardware, the textio packages are simply not synthezisable. What kind of interface is it from the board to where you are trying to write a file?
I think what you're trying to do is analyse how data differs from one run to another.
If you use Signal Tap Logic Analyser, you have an option of extracting the result in a neat text format.
I found this information in this thread: http://www.alteraforum.com/forum/showthread.php?t=764&highlight=text+file
