16614 Discussions
Wrong font size in Quartus, options are not visible
Kai39
Please see the pictures below. Those fonts are either too big or too small, and it's hard to use Quartus under this situation. I tried to change the windows setting or font size setting, but none of them works. I reset my laptop and reinstall Quartus, but still failed. Does anyone know how to resolve this? Thanks.
Nurina
Here's a KDB source that can help with your problem: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd11102011_840.html
Let me know if this solves your solution,
Nurina
Kai39
It did change how the interface looks like, but still some problem exists.
Nurina
Hi there,
We did not receive any response from you to the previous answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
PS: If any answer given by the community or Intel Support are helpful, feel free to give Kudos.
Nurina
Have you tried changing the fonts from the settings in Quartus? If not, go to Tools>Options>General>Fonts
Can you let me know what version of Quartus you're using if the above solution doesn't help?
Nurina
Kai39
Yes, I tried several times, but always, those normal fonts become smaller and the wrong fonts don't change. Also, in the picture below, the bottom of "general" disappears.
My current version is Quartus Prime 20.1 Lite Edition, just downloaded a few days ago.
Thank you very much.
Nurina
We did not receive any response to the previous answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
Nurina
OK, this is a DPI scaling issue. Your monitor resolution might be too high.
Use the following steps:
  1. Right-click on the Quartus shortcut icon on your desktop.
  2. Go to Properties->Compatibility.
  3. Click on "Change high DPI settings".
  4. Tick "Override high DPI scaling behavior".
  5. Then under "Scaling performed by:", select "System".
  6. Then restart Quartus and it should be scaled properly.
As a result the resolution will be lower. But I think if you play around with the different options from step 5 you can find one that works for you perfectly both resolution and scaling wise.
I hope this helps!
Nurina
