Design node type is of Output type but in signal in vector file is bidirectional. (QUARTUS II)
My code for a JK flip flop compiles correctly but the problem I am having is that when I try to run simulation, an error occurs. I've been troubleshooting/debugging for 2 days now with no luck. Any advice? entity jkflop is port ( j,k,clk,pre,clr: in bit; q, qn: out bit); end jkflop; architecture behavior of jkflop is begin PROCESS(clk,pre,clr) variable q1: bit; begin if pre = '0' then q1:= '1'; elsif clr = '0' then q1:= '0'; elsif (clk 'event AND clk = '0') then if (j = '0' AND k = '0') then q1:= q1; elsif (j = '1' AND k = '0') then q1:= '1'; elsif (j = ''0' AND k = '1') then q1:= '0'; else q1:= NOT q1; END if; END if; q<= q1; qn<= NOT q1; END PROCESS; END behavior;Link Copied
My Q and QN waveforms do not simulate correctly.
What error is occurring
--- Quote Start --- What error is occurring --- Quote End --- Warning: Wrong node type for node "q" in vector source file. Design node is of type Output, but signal in vector source file is of type Bidir. Error: Can't simulate mismatched node types. Warning: Wrong node type for node "qn" in vector source file. Design node is of type Output, but signal in vector source file is of type Bidir. Error: Can't simulate mismatched node types. Any time I run my simulation, I receive those warning. My outputs q and qn show unknown values, my simulated results page takes my end time from 1us to 10us, and my inputs have all changed per that results page as well. I don't think half of that stuff is an issue, except for the node type problem....that is what I am trying to solve.
Your vwf isnt setup correctly. I highly suggest you write your own testbench rather than try and use a VWF file for testing.
