17252 Discussions
Zero Packed Or Unpacked Array Dimensions Problems
Hi bros. I want to implement a circuit that run like this:
- If reset = 0, the output data = 12'b0;
- If not, the output data = a vector in the ROM.
And this is my code (I apologize for its length, but you can ignore what is in the concatenation operator)
module ROM_sin
input clk, rst,
input [10:0] addr,
output reg [11:0] data
reg [10:0] temp;
integer i;
reg [11:0] RAM_2048_12BIT [2047:0];
assign MY_ROM = {12'b000000000000, 12'b000000000110, /* lots of values here */ , 12'b111111111001};
always @ (posedge clk or negedge rst)
begin
for (i = 0; i <= 2047; i = i + 1)
begin
assign RAM_2048_12BIT[11:0] = my_rom[11:0];
end
if (!rst)
data <= 12'b0;
else
if(clk)
begin
temp[10:0] = addr;
data = RAM_2048_12BIT[temp];
end
end
endmodule
And when I compiled it, I got an error:
"Error (10053): Verilog HDL error at rom_sin.v(274): can't index object "MY_ROM" with zero packed or unpacked array dimensions"
Please tell me why this error occurs and how to fix it. Thank you so much!
Where is the declaration for MY_ROM?
Also, you should not put a range in the select if you don't need it.
When you put in a range, it makes me thing you are only selecting part of the memory
Without the range it says your intent is to pass the whole element.
assign RAM_2048_12BIT = my_rom;
