17256 Discussions
add new library into the uartus-II
Hello
can any one help to my problem
I have code for p89c51 , it have two libraries one is IEEE and other is FMF. This code uses two files from FMF library 1.gen_utils 2.conversions. I have downloaded code for these FMF library functions and put into vhdl folder next to IEEE library.
In my project I have given path to this FSM folder.
while I run project, Still i am getting following two messages
Error (10481): VHDL Use Clause error at p89c51.vhd(35): design library "FMF" does not contain primary unit "gen_utils"
Error (10481): VHDL Use Clause error at p89c51.vhd(36): design library "FMF" does not contain primary unit "conversions"
how to resolve this issure..
regards
kalyan
I think you're using User Library in Quartus, which is very different than a VHDL library. Please look at the following, as it might answer your question:
http://www.alteraforum.com/forum/showthread.php?t=280&highlight=vhdl+library
