I all,
I tried to instanciate an altdpram with NUMWORDS => 1 and WIDTHA => 1. According to http://quartushelp.altera.com/11.1/mergedprojects/hdl/mega/mega_file_altdpram.htm this is OK:Parameter ; Type ; Required ; Description
NUMWORDS ; Integer ; No ; Number of words stored in memory.
This value must be within the range
2^(WIDTHAD - 1) < NUMWORDS <= 2^WIDTHAD.
If omitted, the default is 2^WIDTHAD.
I get the following error: --- Quote Start --- Error: Assertion error: Value of NUMWORDS parameter requires 0 address lines, but WIDTHAD value, which defines the number of address lines, is 1 Error: Can't elaborate user hierarchy "altdpram:ram" Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 2 errors, 494 warnings Error: Peak virtual memory: 1594 megabytes Error: Processing ended: Thu Jun 28 09:43:13 2012 Error: Elapsed time: 00:02:23 Error: Total CPU time (on all processors): 00:02:20 Error: Quartus II Full Compilation was unsuccessful. 4 errors, 494 warnings --- Quote End --- Has anyone faced this issue? What can I do? P.S.: You may think that it's stupid to instanciate a memory of depth 1. Actually the depth is generic and may be greater than 1, which is why I need a memory. But I need the system to work even if the user wants a depth of 1. Thx Julien
--- Quote Start --- I tried to instanciate an altdpram with NUMWORDS => 1 and WIDTHA => 1. --- Quote End --- Mathematically incorrect, isn't it? 2^(WIDTHAD - 1) seems simply wrong. Most likely,you need to generate a RAM with NUMWORDS = 2 and map it respectively.
As an additional observation, I have no difficulties to set NUMWORDS values smaller than (2^widthad-1) with altsyncram, also NUMWORDS = 1 in a direct instantiation of the VHDL component.
I don't know if there are any differences with altdpram, which it isn't but a wrapper of altsyncram.
