17267 Discussions
altsyncram simulation problem, please help
I have made a RAM using Altera liberary
The declear is like this altsyncram#(.OPERATION_MODE("ROM"),.WIDTH_A(10),.WIDTHAD_A(5),.OUTDATA_ACLR_A("UNUSED"),.INIT_FILE("da_data.mif")) read_da_data (.q_a(buff_DA_data[9:0]),.address_a(count_out[4:0]),.clock0(clk));
and when I use ModelSim to simulate, such error comes out: Module parameter 'WIDTH_A' not found for override.
all the parameter I set have this error,
Module parameter 'OUTDATA_ACLR_A' not found for override.
Module parameter 'OPERATION_MODE' not found for override.
Module parameter 'INIT_FILE' not found for override.
Please Help me about it ,Thanks.
Try writing parameter names in lowercase (operation_mode, width_a, etc.).
Thanks ,the problem solved, indeed write in lowercase, the simulation can operate well.
Thank you for your reply, it helps me a lot.
