17252 Discussions
aocl diagnose failed : AAL issues
Hello
I am trying to run a .aocx file.
when i do aocl diagnose , i get the following :
aocl diagnose: Running diagnose from /home/saravind/bdw_fpga_pilot_opencl_v1.0/bdw_fpga_pilot_opencl_bsp_v1.0/linux64/libexec
ccip_mmd.cpp:1003:serviceAllocateFailed() **Error : Failed to allocate Service
ccip_mmd.cpp:1123:runtimeAllocateServiceFailed() **Error : Runtime AllocateService failed
ccip_mmd.cpp:453:open() **Error : ALIAFU allocation failed
Error: Failed to initialize the OpenCL/AAL system.
Error: Ensure a correct OpenCL image is programmed on the FPGA, and that the CCI driver has been loaded.
Using platform: Altera SDK for OpenCL
CL device ID = 64
Failed clGetDeviceIDs.
Error code: -1
aocl diagnose: failed.
I think this issue is due to some library environment variable settings.
Please let me know if you know of any possible reasons/solutions to this issue.
Thank you.
Your board must come with a "getting started guide" that comes with step by step instructions as to how you should set up your board. Make sure you carefully read and follow the instructions.
