I'm trying to view the profiler results using `aocl report <kernel>.aocx profile.mon`
But I'm getting the following error message: aocl report: Java runtime not installed with Quartus, please reinstall Quartus and ensure the java runtime is included with your install. Reinstalling Quartus didn't help. And there is java included with the install, specifically quartus/linux64/jre/bin and quartus/linux64/jre64/bin are both there. So is some environment variable or path not set right? Where/how is it checking for java? I've been able to do everything in the flow so far (compile and run kernels for both emulator and on the board, debug with gdb, get a profile.mon file generated, etc) so my installation shouldn't be too far off. Any ideas?Link Copied
Hello, it looks for the java runtime in the following location: $QUARTUS_ROOTDIR/linux64/jre64/bin/java - so perhaps the QUARTUS_ROOTDIR is not set to where linux64 is?
You can also try to following to make sure it works - and adjust the QUARTUS_ROOTDIR as appropriate.
user$ echo $QUARTUS_ROOTDIR /tools/linux64/quartus user$ $QUARTUS_ROOTDIR/linux64/jre64/bin/java -version java version "1.8.0_05" Java(TM) SE Runtime Environment (build 1.8.0_05-b13) Java HotSpot(TM) 64-Bit Server VM (build 25.5-b02, mixed mode)- Mark as New
That did it. $QUARTUS_ROOTDIR wasn't set.
(Actually it wasn't successful at first; after setting QUARTUS_ROOTDIR I was still getting the same failure. But then I moved back to my original shell window and directory that hadn't been experimented in and tried it there. It's off and running now) Thanks!
