Hi
can anyone please tell me where is the area report in Quartus II? I have checked almost every report and still cannot find it :confused: thank you!Link Copied
In the "Compilation Report" Tab, both for "Analysis & Synthesis" and for "Fitter", you'll find a "Resource Usage Summary" and a "Resource Utilization by Entity" report.
The navigation pane will also show resource usage.- Mark as New
Hi rbugalho,
I checked the reports you mentioned in post but I still did not get it. what I am looking for is something like 423558 (µm^2), would you help me on this? thanks a lot.- Mark as New
There is no such thing, it does not make sense for an FPGA.
Each FPGA model has a fixed amount of resources (LEs, M*K blocks, etc, etc). And a fixed die size. Your design may or may not use all the resources in your FPGA, but they're there and the die doesn't magically shrink or increase.- Mark as New
Hi rbugalho,
thank you for the tip!
