array initialisation
HI, ive been trying to reset an array using the following lines:
type array_t is array (0 to 60) of integer;
signal array_n : array_t:= ((others=> (others=>'0')));
but i get the following error:
Error (10514): VHDL aggregate error at graph_2.vhd(24): can't determine type of aggregate -- found 0 possible types
please somebody help...
Kind Regards
Integer isn't a logic_vector, although it's represented by it in synthesis.
Simply write array_t:=(others=> 0)
Thank you very much FvM, it worked :D
