hi, i would like to ask..how to assign pin location for my dcmotor coding..i was gonna do a parking gate motor, but the coding no finish yet..this coding can only be used by the motor to rotate left and right without stopping..you can check the attachment for the coding file..
Go to the Pin Planner of Quartus. Assigments->Pin Planner. Or use the button of the tool bar.
i know that, but i do not know how to assign pin for my dc motor on that..
Do you compile the project?
yes i compile it already..thanks..i just manage to assign the pin..but now i cannot load into the programmer, because there is no .sof file..
so it means that i have to buy a new license...?coz i'm using trial version...but last week, i tried to debug the code and everything was going smoothly until this time it suddenly happened..
No. If you have a the correct settings and successful compilation Quartus always generate .sof file. Please check:
"Go to Assignments -> Settings Compilation Process settings Make sure "Run Assembler during compilation" is ticked." I use Quartus 10.1 but didn't support Flex family. But I think Quartus 8 have minor difference with version 10.1.- Mark as New
i already checked that box..but still not working.. now i will try to uninstall this version first, and try installing version 8.1..coz last week I'm using 8.1 version, and it working..
i already installed version 8.1..it's working..! thanks everyone... :)
