17256 Discussions
can't elaborate top level entity hierarchy
Hi All..
in my design shematic file, i have decoder, mux and register file. i create them seperatly and run, simulation and test them with modelsim. but unforchunetly, when i create a shematic file whit this components, and set it as top level, and perfume run simulation it, i see this error
cant elaborate top level entity hierarchy
can eney one help me?, tnx
Does your top-level schematic file have the same name as your project?
If not, you need to set it explicitly in Assignments -> Settings -> General in Quartus II main menu.
If there is problem with hierarchy, check your design to make sure every sub-module is instantiated correctly.
have you output the top level schematic as an HDL file? Modelsim cannot simulate schematic files.
Solve my problem, Thanks lot:)
