17255 Discussions
can you check the error for stopwatch using de2 board
the error is that after 59min it goes 60 61 62min....... after 99min, it become 00min 00s00
actually it need to change in hour after 59min
i want to show my stopwatch for max 99hr 59min 59s99
this is the stopwatch coding using VHDL
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity stop_watch is
Port ( clk : in STD_LOGIC;
start : in STD_LOGIC;
reset : in STD_LOGIC;
hex0 : out STD_LOGIC_VECTOR (3 downto 0);
hex1 : out STD_LOGIC_VECTOR (3 downto 0);
hex2 : out STD_LOGIC_VECTOR (3 downto 0);
hex3 : out STD_LOGIC_VECTOR (3 downto 0);
hex4 : out STD_LOGIC_VECTOR (3 downto 0);
hex5 : out STD_LOGIC_VECTOR (3 downto 0);
hex6 : out STD_LOGIC_VECTOR (3 downto 0);
hex7 : out STD_LOGIC_VECTOR (3 downto 0));
end stop_watch;
architecture Behavioral of stop_watch is
signal count0:std_logic_vector(3 downto 0):=(others=>'0');
signal count1:std_logic_vector(3 downto 0):=(others=>'0');
signal count2:std_logic_vector(3 downto 0):=(others=>'0');
signal count3:std_logic_vector(3 downto 0):=(others=>'0');
signal count4:std_logic_vector(3 downto 0):=(others=>'0');
signal count5:std_logic_vector(3 downto 0):=(others=>'0');
signal count6:std_logic_vector(3 downto 0):=(others=>'0');
signal count7:std_logic_vector(3 downto 0):=(others=>'0');
begin
process(clk,reset)
begin
if reset='1' then
count0<=(others=>'0');
count1<=(others=>'0');
count2<=(others=>'0');
count3<=(others=>'0');
count4<=(others=>'0');
count5<=(others=>'0');
count6<=(others=>'0');
count7<=(others=>'0');
elsif rising_edge(clk) then
if start='1' then
if (count7=x"9" and count6=x"9" and count5=x"5" and count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then
elsif (count6=x"9" and count5=x"5" and count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then
count7<=count7+1;
elsif (count5=x"5" and count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then
count6<=count6+1;
elsif (count4=x"9" and count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then
count5<=count5 + 1;
elsif (count3=x"5" and count2=x"9" and count1=x"9" and count0=x"9") then
count4<=count4 + 1;
elsif (count2=x"9" and count1=x"9" and count0=x"9") then
count3<=count3 + 1;
elsif (count1=x"9" and count0=x"9") then
count2<=count2 + 1;
elsif (count0=x"9") then
count1<=count1 + 1;
else
count0<=count0 + 1;
end if;
end if;
end if;
end process;
hex0<=count0;
hex1<=count1;
hex2<=count2;
hex3<=count3;
hex4<=count4;
hex5<=count5;
hex6<=count6;
hex7<=count7;
end Behavioral;
you haven't constrained your counters.
I will do it as nested ifs starting from count0 towards count7:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity stop_watch is Port ( clk : in STD_LOGIC; start : in STD_LOGIC; reset : in STD_LOGIC; hex0 : out STD_LOGIC_VECTOR (3 downto 0); hex1 : out STD_LOGIC_VECTOR (3 downto 0); hex2 : out STD_LOGIC_VECTOR (3 downto 0); hex3 : out STD_LOGIC_VECTOR (3 downto 0); hex4 : out STD_LOGIC_VECTOR (3 downto 0); hex5 : out STD_LOGIC_VECTOR (3 downto 0); hex6 : out STD_LOGIC_VECTOR (3 downto 0); hex7 : out STD_LOGIC_VECTOR (3 downto 0) ); end stop_watch; architecture Behavioral of stop_watch is signal count0:std_logic_vector(3 downto 0):=(others=>'0'); signal count1:std_logic_vector(3 downto 0):=(others=>'0'); signal count2:std_logic_vector(3 downto 0):=(others=>'0'); signal count3:std_logic_vector(3 downto 0):=(others=>'0'); signal count4:std_logic_vector(3 downto 0):=(others=>'0'); signal count5:std_logic_vector(3 downto 0):=(others=>'0'); signal count6:std_logic_vector(3 downto 0):=(others=>'0'); signal count7:std_logic_vector(3 downto 0):=(others=>'0'); begin process(clk,reset) begin if reset = '1' then count0 <= (others=>'0'); count1 <= (others=>'0'); count2 <= (others=>'0'); count3 <= (others=>'0'); count4 <= (others=>'0'); count5 <= (others=>'0'); count6 <= (others=>'0'); count7 <= (others=>'0'); elsif rising_edge(clk) then if start='1' then if count0 /= x"9" then count0 <= count0 + 1; else count0 <= x"0"; if count1 /= x"9" then count1 <= count1 + 1; else count1 <= x"0"; if count2 /= x"9" then count2 <= count2 + 1; else count2 <= x"0"; if count3 /= x"5" then count3 <= count3 + 1; else count3 <= x"0"; if count4 /= x"9" then count4 <= count4 + 1; else count4 <= x"0"; if count5 /= x"5" then count5 <= count5 + 1; else count5 <= x"0"; if count6 /= x"9" then count6 <= count6 + 1; else count6 <= x"0"; if count7 /= x"9" then count7 <= count7 + 1; else count7 <= x"0"; end if; end if; end if; end if; end if; end if; end if; end if; end if; end if; end process; hex0 <= count0; hex1 <= count1; hex2 <= count2; hex3 <= count3; hex4 <= count4; hex5 <= count5; hex6 <= count6; hex7 <= count7; end Behavioral;
Thank sir
I will test it after I cameback from sch
hello sir
for the time set, i need to do with keypad or keyboard.
i don't know how to write for this code.
this is the time to show in LCD. i cannot find the problem. i want to show hour for 01-12. but its also include 00. so after 12hr it become 00hr and then 01 hr. that is the wrong. can u find the error, sir. plz help me. that is very important for me ................. thank sir
library IEEE;
entity counter_up is
SET : in STD_LOGIC;
BTN0 : in STD_LOGIC;
BTN1 : in STD_LOGIC;
BTN2 : in STD_LOGIC;
BTN3 : in STD_LOGIC;
BTN4 : in STD_LOGIC;
BTN5 : in STD_LOGIC;
AM : out STD_LOGIC;
hex5 : out STD_LOGIC_VECTOR (3 downto 0));
end counter_up;
architecture Behavioral of counter_up is
signal count4:std_logic_vector(3 downto 0):=x"1";
signal reg:std_logic:='0';
begin
process(clk,reset)
begin
if reset='1' then
count4<=x"1";
if SET='1' then
if (count0=x"9" and BTN0='1') then
count0<=x"0";
elsif (BTN0='1') then
count0<=count0+1;
elsif (count1=x"5" and BTN1='1') then
count1<=x"0";
elsif (BTN1='1') then
count1<=count1+1;
elsif (count2=x"9" and BTN2='1') then
count2<=x"0";
elsif (BTN2='1') then
count2<=count2+1;
elsif (count3=x"5" and BTN3='1') then
count3<=x"0";
elsif (BTN3='1') then
count3<=count3+1;
elsif (count4=x"C" and BTN4='1') then
count4<=x"1";
elsif (BTN4='1') then
count4<=count4+1;
elsif(BTN5='1') then
reg<=not(reg);
end if;
else
if (count4=x"C" and count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then
reg<=not(reg);
count4<= x"1";
elsif (count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then
count4<=count4 + 1;
elsif (count2=x"9" and count1=x"5" and count0=x"9") then
count3<=count3 + 1;
elsif (count1=x"5" and count0=x"9") then
count2<=count2 + 1;
count1<=count1 + 1;
else
count0<=count0 + 1;
end if;
end if;
end if;
end process;
AM <= reg;
hex0<=count0;
hex1<=count1;
hex2<=count2;
hex3<=count3;
hex4<=
count4 when (count4<x"A") else
"00"&count4(2 downto 1) when count4=x"C" else
"00"&count4(0);
hex5<=
"0001" when (count4=x"A" or count4=x"B" or count4=x"C") else
"0000";
end Behavioral;
