combinational delayline
hope someone knows the answer to this one.
The basis of my design is a compinational delayline made from buffers from an input pin to an output pin with each buffer tapped into the D of a Dtype reg.
I have 4 delaylines and they must be of the same timing. I have an empty stratix III to perform this starting point where I will then lock the cells and routing for the rest of the design.
Try as I may I cannot get these 4 circuits to be the same as the router seems to arbitarly place the design. How can I tell the router that these are critcal paths. There are no clocks or set and hold timing as this delay is purely combinational.
Robert
You could try by specifying an 'impossible' Tpd from input to output. The router will try its best.
