17261 Discussions
compiling error: quartus prime lite quitting unexpectedly
jack000
It quit during compiling fitter.
Here's my preview report:
Problem Details
Error:
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3270
Stack Trace:
    0x48b8c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID::operator unsigned __int64 + 0x2bb4c (DDB_DYGR)
    0x1e780: std::_Hash<std::_Umap_traits<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,std::_Uhash_compare<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID> >,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> >,0> >::_Hashval + 0x10 (DDB_DYGR)
    0x1fc3e: std::unordered_map<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID,DYGR_BLK_PORT_INFO const * __ptr64,STL_HASH_FUNCTOR<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::equal_to<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID>,std::allocator<std::pair<DYGR_BLK_PHYSICAL_IMPLEMENTATION::PORT_ID const ,DYGR_BLK_PORT_INFO const * __ptr64> > >::operator[] + 0x1e (DDB_DYGR)
    0x1db2b: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xff (DDB_DYGR)
    0x189d6: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x66 (DDB_DYGR)
    0x3433b: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x83 (DDB_DYGR)
    0x15360: DYGR_DIE_INFO_BODY::load_data + 0x2a4 (DDB_DYGR)
    0x1d1f7: MPP_ROOT::start + 0x587 (COMP_MPP)
     0x5e5a: qfit_execute_mpp + 0x42 (comp_qfit_legacy_flow)
     0x555b: QFIT_FRAMEWORK::execute + 0x22f (comp_qfit_legacy_flow)
     0x2768: qfit_legacy_flow_run_legacy_fitter_flow + 0x1d4 (comp_qfit_legacy_flow)
    0x14410: TclInvokeStringCommand + 0xf0 (tcl86)
    0x161e2: TclNRRunCallbacks + 0x62 (tcl86)
    0x17a65: TclEvalEx + 0xa65 (tcl86)
    0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86)
    0xa5646: Tcl_EvalFile + 0x36 (tcl86)
    0x12877: qexe_evaluate_tcl_script + 0x367 (comp_qexe)
    0x11ac3: qexe_do_tcl + 0x343 (comp_qexe)
    0x16c34: qexe_run_tcl_option + 0x584 (comp_qexe)
    0x39285: qcu_run_tcl_option + 0xf95 (comp_qcu)
    0x1658d: qexe_run + 0x39d (comp_qexe)
    0x17371: qexe_standard_main + 0xc1 (comp_qexe)
     0x2262: qfit2_main + 0x82 (quartus_fit)
    0x13258: msg_main_thread + 0x18 (CCL_MSG)
    0x14a5e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x16af0: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12af1: msg_exe_main + 0xa1 (CCL_MSG)
     0x2a02: __tmainCRTStartup + 0x10e (quartus_fit)
    0xf0cdb: uaw_wcsrchr + 0xeb21b (KERNEL32)
    0x87ddf: uaw_wcsrchr + 0x8231f (KERNEL32)
   0x1ba2d7: ZwWaitLowEventPair + 0x1abb97 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 20.1.1
Build: 720
Edition: Lite Edition
Thank you
SyafieqS
The first step for Quartus crashing is to always delete the db and incremental_db folders from your project directory, start Quartus again, and recompile from scratch.
SyafieqS
May I know if there is any update from previous reply?
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
