17266 Discussions
connect between sub-blocks at the same and differentE component
Hi ,
i want to connect the control signal - Seed_En (attached file) that his source block is LockStateMachine to :
a. The sub-blocks PN_transmitter at the same component - Rx .
do i need to define the instantiation of the Seed_EN at the Rx block or at LockStateMachine block ?
b. The sub-blocks PN_transmitter at different component - Tx .
do i need to define the instantiation of the Seed_EN at the Tx block or at LockStateMachine block ?
do i need to define output port to the component Rx and instantiate between the Seed_En and the new port ?
do i need to define input port to the component Tx and instantiate between the Seed_En and the new port ?
btw - every component and sub block is different file at the project and there is Top file that define the I/O 's and there is TestBench file
for the project for simulation.
Thanks .
Inside component "RX" you would write:
entity RX...
seed_EN_out : out std_logic;
architecture...
signal seed_EN : std_logic;
begin
lock_unit : entity work.lockstatemachine
port map(...
seed_EN => seed_EN,
pn_unit : entity work.pngeneratorrx
port map(...
seed_EN => seed_EN,
end architecture...
did you mean at the instantiate of :
port map(...
seed_EN_out => seed_EN,
port map(...
end architecture...
do i need to define seed_En as input port at the entities: lockstatemachine,pngeneratorrx ?
At the second entity - Tx ,
do i need to define seed_En_in as input port and instantiate between the Seed_En and the new port ?
Thanks .
seed_EN is juist a wire connecting the seed_EN_out ports of the two entites. It would be declared as an internal signal in the design file that instantiates the two entites.
o.k ,
i will define seed_EN_out as output port from lockstatemachine , but should i define seed_En_in as input port at the entities:pngeneratortx,pngeneratorrx ?
and then instantiate : seed_EN_out => seed_EN_in ?
if not , how will seed_EN be connection between lockstatemachine and the two entities ?
