17264 Discussions
counting output pulse(project)
Hi everyone,
I would like to count the number of pulse outputting to a device, so that ,at some point, i can stop it from outputting. However i dont know how to do that..
I thought of using time to control the output signal, however it fails.
This question has been bothering me for 2-3 weeks, i still can't figure out. I hope you guys can help me. Thank you so much.
For more information,
I am actually building a system using FPGA to trigger the stepper motor in my lab. However, i want to stop the motor at some points, say 180 degree.
I have done all the calculation. In order to make it rotate 180 degree, i need to have 50 pulse outputting from FPGA.
Please help me. What should i do. Thank you
But why is it difficult to count 50 pulses. You need to explain the difficulty. are pulses equal in period?
kaz,
yes pulses are equal in period,
like,, i need to stop it at some point, say 50 pulses...however i dont know how to do it , u have any idea?
--- Quote Start ---
kaz,
--- Quote End ---
50 pulses each n clocks (per pulse period) then you need to count 0 ~ 50n-1. reset counter at start and then enable counter when pulse is high only.
I don't see what is so hard about it.
oh sorry, but i am just a beginner, i tried
should i use "repeat"?
i can only use a counter to divide the frequency...
and then i got stuck
Hi Sam,
Please use this as reference.
module pulse_atN(Clk, Reset, Pulse, N);
parameter WIDTH = 10;
input Clk, Reset;
input [WIDTH-1:0] N;
reg [WIDTH-1:0] Nlast;
reg [WIDTH-1:0] Count;
output Pulse;
assign Pulse = (Count == N-1) && (N != 0);
always @ (posedge Clk, posedge Reset)
begin : PULSE_GENERATOR
if(Reset)
Count <= 0;
else
begin
// nonblocking so check occurs with old Nlast
Nlast <= N;
if(Nlast != N)
Count <= 0;
else if(Count == N-1)
begin
Count <= 0;
Pulse = 1;
end
else
begin
Count <= Count + 1;
Pulse = 0;
end
end
end
endmodule
input Clk, Reset;
output Pulse;
if(Reset)
Count <= 0;
else
begin
Nlast <= N;
if(Nlast != N)
Count <= 0;
begin
Count <= 0;
Pulse = 1;
end
else
begin
Count <= Count + 1;
Pulse = 0;
end
end
end
endmodule
Hi Sam,
Please refer this example if might help.
http://www.edaboard.com/thread280011.html
