Hi everyone,
I would like to count the number of pulse outputting to a device, so that ,at some point, i can stop it from outputting. However i dont know how to do that.. I thought of using time to control the output signal, however it fails. This question has been bothering me for 2-3 weeks, i still can't figure out. I hope you guys can help me. Thank you so much. For more information, I am actually building a system using FPGA to trigger the stepper motor in my lab. However, i want to stop the motor at some points, say 180 degree. I have done all the calculation. In order to make it rotate 180 degree, i need to have 50 pulse outputting from FPGA. Please help me. What should i do. Thank youLink Copied
But why is it difficult to count 50 pulses. You need to explain the difficulty. are pulses equal in period?
kaz,
yes pulses are equal in period, like,, i need to stop it at some point, say 50 pulses...however i dont know how to do it , u have any idea?- Mark as New
--- Quote Start --- kaz, yes pulses are equal in period, like,, i need to stop it at some point, say 50 pulses...however i dont know how to do it , u have any idea? --- Quote End --- 50 pulses each n clocks (per pulse period) then you need to count 0 ~ 50n-1. reset counter at start and then enable counter when pulse is high only. I don't see what is so hard about it.
oh sorry, but i am just a beginner, i tried
should i use "repeat"? i can only use a counter to divide the frequency... and then i got stuck- Mark as New
Hi Sam,
Please use this as reference. module pulse_atN(Clk, Reset, Pulse, N); parameter WIDTH = 10; input Clk, Reset; input [WIDTH-1:0] N; reg [WIDTH-1:0] Nlast; reg [WIDTH-1:0] Count; output Pulse; assign Pulse = (Count == N-1) && (N != 0); always @ (posedge Clk, posedge Reset) begin : PULSE_GENERATOR if(Reset) Count <= 0; else begin // nonblocking so check occurs with old Nlast Nlast <= N; if(Nlast != N) Count <= 0; else if(Count == N-1) begin Count <= 0; Pulse = 1; end else begin Count <= Count + 1; Pulse = 0; end end end endmodule- Mark as New
