17257 Discussions
daft question about Verilog parameter
Hi All,
Is it legal to define a new parameter based on a previously declared one ?
Mark
parameter HS64x8_XINC = 86;
parameter HS64x8_X0POSN = 70;
parameter HS64x8_X1POSN = (HS64x8_X0POSN+(HS64x8_XINC*1));
parameter HS64x8_X2POSN = (HS64x8_X0POSN+(HS64x8_XINC*2));
parameter HS64x8_X3POSN = (HS64x8_X0POSN+(HS64x8_XINC*3));
parameter HS64x8_X4POSN = (HS64x8_X0POSN+(HS64x8_XINC*4));
Yes you can do that.
I often do stuff like:
module module_name# (
parameter BUS_WIDTH = 32,
parameter BUS_WIDTH_DEC = clogb2(BUS_WIDTH)
ports....
where clogb2 is a function so I can overload the parameter at the instantiation and have it propogate to the other parameter
Thank you very much
Oh boy...
I now have the problem where I change the parameter assignment within the Verilog source file, re-compile the entire project and discover that resulting module has the old parameter assignment. I can see this by looking at hierarchy, then mousing over the module name - a parameter list pops up for that module...
Almost sounds like a caching problem.
Any thoughts welcome.
-Mark
just found that if I rename all of the parameters (add an 'A' in the name etc.) this forces the correct values to be taken --- once
Just found the parameter within a BSF file, so the .V may need to have a new (updated) symbol file created every time you change a parameter...
