17255 Discussions
declaring port as array type
How to solve a problem with declaring port as array type?
I want to make entity multiplexer like this:
entity multiplexer is generic( sel_bits: integer := 2; data_width: integer := 1 ); port( input: in array (2**sel_bits-1 downto 0) of bit_vector(data_width-1 downto 0); -- this won't do. I could use package, but is there this kind of solution? output: out bit_vector(data_width-1 downto 0); sel: in bit_vector (sel_bits-1 downto 0) ); end entity multiplexer;
you cannot declare an array like that. First you need to declare the type and then create a signal of that type. In this case you will need to declare the array type in a package.
type my_array_t is array(2**sel_bits-1 downto 0) of bit_vector(data_width-1 downto 0);
--in the port
input : my_array_y;
The upshot of this is that you will need to decalre the generics as constants in the package also.
Or for more flexibility you could define your own array type using an unconstrained array (VHDL-2008). Define it in a separate file like this:
type StdLogicVectorArray is array(integer range <>) of std_logic_vector;
Include it in the library section
library work; use work.MyTypeFile.all;
Now you are able to use it for your port like this:
port( input : in StdLogicVectorArray(0 to (2**sel_bits-1))((data_width-1 downto 0) downto 0); (...) );
Hope that helps.
Regards, Sören
I was hoping it would help, but
isn't correct. It says that std_logic_vector is unconstrained, or something like that... When I try to constrain it with
type StdLogicVectorArray is array(integer range <>) of std_logic_vector(0 to 100)
and use it in code like this
it complains that element type in StdLogicVectorArray is constrained, so I can't do that.
Now what?
You need to set he vhdl version to 2008 in the project settings.
Cool, it works. Thank you.
