17268 Discussions
different clock'event on the same file
Is it possible to write 2 processes, one activated by clock rise and the other by clock fall that could write the same register? I'm trying to construct a register file that may receive 2 sources of data. If they are for different register, it is ok, but for different data for the same register, I pretend to modify the same register on different clock edges. ¿Is it possible? What happens first? Rise edge or fall edge?
I get 2 errors:
Error: Can't resolve multiple constant drivers for net "register_array[0][31]" at regfile.vhd(109)
line 109 is in green color
Error: Constant driver at regfile.vhd(119)
line 119 is in brown color
Any suggestion?
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY regfile IS
PORT(
RegWrite_pipe0 : IN STD_LOGIC;
RegWrite_pipe1 : IN STD_LOGIC;
read_register_1_address_pipe0 : IN STD_LOGIC_VECTOR( 4 DOWNTO 0);
read_register_2_address_pipe0 : IN STD_LOGIC_VECTOR( 4 DOWNTO 0);
read_register_1_address_pipe1 : IN STD_LOGIC_VECTOR( 4 DOWNTO 0);
read_register_2_address_pipe1 : IN STD_LOGIC_VECTOR( 4 DOWNTO 0);
read_register_1_data_pipe0 : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
read_register_2_data_pipe0 : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
read_register_1_data_pipe1 : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
read_register_2_data_pipe1 : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
write_register_address_pipe0 : IN STD_LOGIC_VECTOR( 4 DOWNTO 0);
write_register_data_pipe0 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
write_register_address_pipe1 : IN STD_LOGIC_VECTOR( 4 DOWNTO 0);
write_register_data_pipe1 : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
clock : IN STD_LOGIC;
reset : IN STD_LOGIC
END regfile;
ARCHITECTURE behavior OF regfile IS
TYPE register_file IS ARRAY (0 TO 31) OF STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL register_array : register_file;
BEGIN
-- read registers 1 & 2 on rising edge of clock, i.e. they are registered
PROCESS
BEGIN
WAIT UNTIL clock'event and clock = '1';
read_register_1_data_pipe0 <= register_array(CONV_INTEGER(read_register_1_address_pipe0));
read_register_2_data_pipe0 <= register_array(CONV_INTEGER(read_register_2_address_pipe0));
read_register_1_data_pipe1 <= register_array(CONV_INTEGER(read_register_1_address_pipe1));
read_register_2_data_pipe1 <= register_array(CONV_INTEGER(read_register_2_address_pipe1));
END PROCESS;
PROCESS
BEGIN
IF reset = '1' THEN
-- Initial register values on reset are ceros
-- use loop to automatically generate reset logic for all registers
FOR i IN 0 TO 31 LOOP
register_array(i) <= X"00000000";
END LOOP;
-- Write back to register - don't write to register 0
ELSIF (RegWrite_pipe0 = '1') AND (RegWrite_pipe1 = '0') AND (write_register_address_pipe0 /= 0) THEN
register_array(CONV_INTEGER(write_register_address_pipe0)) <= write_register_data_pipe0;
ELSIF (RegWrite_pipe0 = '0') AND (RegWrite_pipe1 = '1') AND (write_register_address_pipe1 /= 0) THEN
register_array(CONV_INTEGER(write_register_address_pipe1)) <= write_register_data_pipe1;
ELSIF (RegWrite_pipe0 = '1') AND (RegWrite_pipe1 = '1') AND (write_register_address_pipe0 /= 0) AND (write_register_address_pipe1 /= 0) THEN
IF (write_register_address_pipe0 /= write_register_address_pipe1) THEN
ELSE
-- para este caso el otro registro se escribe con el flanco de bajada del reloj
END IF;
END IF;
end process;
PROCESS
BEGIN
WAIT UNTIL clock'event and clock = '0';
IF (RegWrite_pipe0 = '1') AND (RegWrite_pipe0 = '1') AND (write_register_address_pipe0 /= 0) AND (write_register_address_pipe1 /= 0) THEN
IF (write_register_address_pipe0 = write_register_address_pipe1) THEN
END IF;
END IF;
end process;
END behavior;
Don't think of VHDL, but the underlying hardware. There are no registers that are triggered of both edges(in any FPGAs), so whether VHDL could do it or not is irrelevant. You need two separate registers to clock the data, one rising and one falling, and then your own arbitration mux to determine which one is valid.
