17268 Discussions
differential signals on pins - schematic assignment
On the schematic I have an input named clock. In reality this should be a differential signal. Meaning, I should assign two pins instead of one.
Likewise, I have LVDS outputs coming from an LVDS Megafunction. These are also single signals on the schematic. And they should have differential pins assigned.
The Pin Planner somehow is not supporting this...
As in HDL design descriptions, you'll connect the positive pin only in the schematic. The negative pin is assigned automatically by selecting a differential IO standard.
Thanks, that is somewhat counter intuitive and should be mentioned on a prominent place.
