17268 Discussions
error 10161 when importing vhdl packages to system verilog
My toplevel design is in system verilog, I import a VHDL package with record type, quartus errors with "Error (10161): Verilog HDL error at dummy_sysver.sv(3): object "dummy_vhd_pkg" is not declared"
To simulate I used modelsim -mixedsvvh and I don't have any problem simulating. however when I try compiling the design with quartus I get the error above.
I made sure all signal are plain lowercase, I've also tried compiling vhdl in a different library.
I have also tried creating a system verilog package with packed structure mimicking the vhdl records, compilation goes a bit further, but then I get error indicating the vhdl record output don't exist.
anything else I could try ?
for reference :
I am using Quartus 14.1
---- my vhdl package:----
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
package dummy_vhd_pkg is
type dummy_vhd_type1 is record
dummy_vhd_type1_sig1 : std_logic; --
dummy_vhd_type1_sig2 : std_logic; --
end record;
constant dummy_vhd_type1_init : dummy_vhd_type1 := (
dummy_vhd_type1_sig1 => '0',
dummy_vhd_type1_sig2 => '1'
end package;
--- vhdl code: ----
library ieee;
use work.dummy_vhd_pkg.all;
entity dummy_vhd is
port(
clk : in std_logic;
rst : in std_logic;
output_1 : out dummy_vhd_type1
end dummy_vhd;
architecture rtl of dummy_vhd is
signal output_sig1: dummy_vhd_type1;
begin
output_1 <= output_sig1;
proc1 : process(clk,rst) is
begin
if rst = '1' then
output_sig1 <= dummy_vhd_type1_init;
elsif rising_edge(clk) then
output_sig1.dummy_vhd_type1_sig1 <= output_sig1.dummy_vhd_type1_sig2;
output_sig1.dummy_vhd_type1_sig2 <= output_sig1.dummy_vhd_type1_sig1;
end if;
end process;
end rtl;
---- and finally toplevel system verilog: ---
import dummy_vhd_pkg::*;
module dummy_top_sv
input logic clk,
input logic rst,
output logic dummy_sv_1_1
dummy_vhd_type1 output_1;
assign dummy_sv_1_1 = output_1.dummy_vhd_type1_sig1;
dummy_vhd dummy_vhd_inst1
.clk(clk),
.rst(rst),
.output_1(output_1)
endmodule
I would raise a case with Altera MySupport. Their SV support isnt full, and other vendors (cadence in particular) have a terrible time importing records from VHDL in to SV, so this isnt just a Quartus problem.
For reference:
Modelsim also has a problem with VHDL record that contain arrays that have 0 length, but this is more a System verilog limitation
Cadence cannot import any records that contain types other than std_logic or std_logic_vector, and nested records are also not possible.
Thanks Tricky,
In the end I had to modify the VHDL toplevel record port into various SLV port.
