error 10559 VHDL
I was wondering if anyone can shed some light on this error that I managed to obtain.
Error (10559): VHDL Subprogram Call error at user_functions.vhd(100): actual for formal parameter "s" must be a "signal"
This is the chunk of code where the error occurs it is a function designed to count the rising edges on a signal. and this is to be implemented in main body of the code 4 times, as I need a counter for four signals.
FUNCTION COUNTER(Z:std_logic; Reset:std_logic) RETURN natural IS
variable count: natural range 0 to 65535;
variable Q: natural range 0 to 65535;
begin
(line 100) if (rising_edge(Z)) then
if Reset = '0' then
count := 0;
else
count := count + 1;
end if;
end if;
Return count;
end;
END user_functions;
Is it that I cannot use a subprogram within a new function description?
Let me know if you require more information.
The rising edge function requires the input to be a signal because it uses various attributes that only exist on a signal. The problem is that Z is a constant.
But I don't really understand this function. The variables will be re initialised every time the function is called, so it will only ever return 0 or 1. Why are you using a function and not a process?
--- Quote Start ---
begin
if Reset = '0' then
count := 0;
else
count := count + 1;
end if;
end if;
Return count;
end;
END user_functions;
--- Quote End ---
Hi ,
I dont where "s" is defined as a signal for variable :
Also this should be put in a process , functions are mostly used for mathematical or data conversion tasks .
Would help if i could see how is it called within the main architecture .
Regards ,
Ahmed Asim Ghouri
Embedded Strings inc
Website : www.emstrings.com
Email : support@emstrings.com
You are trying to describe registers (a counter) in a subprogram. That's not possible. Functions must be memoryless and can't respectively use edge sensitive expressions.
To elaborate a bit about the problem, the only case where a register in a subprogram can be synthesized is a construct like below. But it won't work for a counter because the out port can't be read inside the procedure.
procedure ff ( signal clk: in std_logic; signal d : in std_logic; signal q : out std_logic) is begin if rising_edge(clk) then q <= d; end if; end;
