17261 Discussions
error: assigning to 'int *' from incompatible type 'void *' strICtLy_conFidEnTial[strICtlY_CoNfidEnT
syam404
HLS compilation of polar ip generates these errors. How to remove these. Please help us.
Syam
syam404
@Altera_Forum  please look this problem I am trying it out from two weeks.
Syam
BoonBengT_Altera
Hi @syam404,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
My guess is that there should be a casting required in this case.
Hence would suggest to following changes to your code:
- Old code : int *VERY_toP_SEcRET = stRicTlY_ConfiDeNtial(sizeof(int)..
- New code : int *VERY_toP_SEcRET = (int*)stRicTlY_ConfiDeNtial(sizeof(int)..
Hope that clarify, and please do share the code snippet if I misunderstand the situation.
Best Wishes
BB
syam404
Thank you sir 6 errors got resolved one error is remained
Syam
syam404
this error in 231 is different from other errors could please say how it could be resolved
Syam
BoonBengT_Altera
Hi @syam404,
Based on the error message, the variable stRicTlY_ConfiDeNtial are already in the correct type.
Please remove the casting for that line of code and see if there is a different error.
If based on the previous screenshot where the void* error are coming up, double check on the function where the line #231 are, to ensure there is a return type declare is that is what is intended.
Hope that clarify.
Best Wishes
BB
BoonBengT_Altera
Hi @syam404,
Good day, just checking in to see if there is any further doubts in regards to this matter.
Hope we have clarify your doubts.
Best Wishes
BB
BoonBengT_Altera
Hi @syam404,
Greetings, as we do not receive any further clarification on what is provided, we would assume challenge are resolved. Hence thread will no longer be monitored. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
