error quartus II
hi everyone
i've just installed quartus II v9.0 in windows vista
and i've come acrossed this error:
"Internal Error: Sub-system: ATCL, File: /quartus/ccl/atcl/atcl_root.cpp, Line: 334
Error: "ATCL": Can't find a usable init.tcl in the following directories:
C:/Programas/altera/90/quartus/bin/tcl8.4 C:/Programas/altera/90/quartus/lib/tcl8.4 C:/Programas/altera/90/quartus/lib/tcl8.4 C:/Programas/altera/90/lib/tcl8.4 C:/Programas/altera/90/quartus/library C:/Programas/altera/90/library C:/Programas/altera/90/tcl8.4.11/library C:/Programas/altera/tcl8.4.11/library
This probably means that Tcl wasn't installed properly.
Stack Trace:
0x2225 : err_report_internal_error + 0x15 (CCL_ERR)
0xEF4B : atcl_create_interpreter + 0x13B (ccl_atcl)
0x191C : thr_thread_var_get + 0xC (ccl_thr)
0x1F19D : atcl_get_interpreter + 0x1D (ccl_atcl)
0x2BD3 : CONW_WND::OnCreate + 0x143 (prj_conw)
End-trace
Quartus II Version 9.0 Build 132 02/25/2009 SJ Web Edition"
anyone can help me?
i'v tried to reinstall it....i don't know what to do.....
What's your actual quartus\bin location? Does it contain a folder tcl8.4 and init.tcl within?
If not, have they been installed in a different location?
I guess, it may be a Windows locales problem with the spanish version.
i installed the complete version of web edition, with custom settings, except the installer had a pre defined install directory wich was c:\altera and i changed it to c:\Programas\altera
im using vista portuguese version
"Programas" is the folder Program Files....
do you think i should install it in the pre defined directory?
Victor_Zucherato
I've tried this and worked for me. No ones in internet had gaved me the right thing to do. Thank you very much!
I just guessed, that their may be a problem with the directory naming. Using c\altera may be a solution, but I don't know, if it's possible under Vista at all. The other option is to ask Altera support.
I now got the same issue with Altera 12.1 SP1 and Windows 7 x64. So it seems to be not fixed yet...
EDIT: found the workaround to use "program files" instead of the localized program files folder. Now it works for me!
