error with using a macro
Example with a_74283.
LIBRARY altera;
USE altera.maxplus2.all;
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY macro_eg IS
PORT
num_a :IN STD_LOGIC_VECTOR (4 DOWNTO 1);
num_b :IN STD_LOGIC_VECTOR (4 DOWNTO 1);
carry_in :IN STD_LOGIC;
carry_out :OUT STD_LOGIC;
sum_out :OUT STD_LOGIC_VECTOR (4 DOWNTO 1)
END macro_eg;
ARCHITECTURE adder OF macro_eg IS
COMPONENT a_74283
PORT
cin :IN STD_LOGIC;
cout :OUT STD_LOGIC;
sum :OUT STD_LOGIC_VECTOR (4 DOWNTO 1)
END COMPONENT;
BEGIN
add1 : a_74283 PORT MAP (a => num_a, b => num_b, cin => carry_in, cout => carry_out, sum => sum_out);
END;
but I get, Error: Node instance add1 instantiates undefined entity a_74283 .
I have the same problem with using a User Defined macro (I just include/add the folder of the VHDL program that is going to be used as the macro in the User Libraries).
I have no problem/errors using macros in AHDL (using the INCLUDE keyword).
Thank you
Ther are no macros in VHDL.
Have you including the source code for a_74283 in the project, or have you included the correct library?
I only added the:
LIBRARY altera;
in my program, as the a_74283 component is in the maxplus2.vhd file under maxplus2\vhdl93\altera folder (there from installation of MAX+plus II).
I am not sure exactly where the source code for the a_74283 component is situated (from the install of MAX+plus II)?
I would have thought maxplus2 should know where its own libraries are. But the error you have is an error of missing source code.
ANy reason you're using maxplus2? its a very old program.
I am trying to teach myself FPLDs in AHDL, VHDL and Verilog.
The Technikon I attended added an FPLD course (in Graphic Design Entry, AHDL & VHDL) after I graduated, so I bought the kit from the lecturer (a while back). I have only recently started with it. The FPLD (EPM7032SLC44-10) is also obsolete. But because I am working from course notes and MAX+plus II is still available, I am using it as a beginner.
Back to the problem:
I also get the error for using a user macro/component. I use a previous exercise as a component; I add the folder of the exercise (component to use) in User Libraries. Following is the program (exercise) using exercise 1v as a component:
-- Exercise 14v: A 4-Bit Up Counter Using a Macro as the 7-Segment Display Decoder
ENTITY Ex14v IS
PORT
clk :IN BIT;
SSout :OUT INTEGER RANGE 127 DOWNTO 0
END Ex14v;
ARCHITECTURE usermacro OF Ex14v IS
SIGNAL cnt :INTEGER RANGE 15 DOWNTO 0;
COMPONENT ex1v IS
PORT
bn :IN INTEGER RANGE 15 DOWNTO 0;
SS :OUT INTEGER RANGE 127 DOWNTO 0
END COMPONENT;
BEGIN
PROCESS
BEGIN
WAIT UNTIL clk'EVENT AND clk = '1';
cnt <= cnt + 1;
END PROCESS;
decoder :ex1v PORT MAP (cnt,SSout);
END;
Following is exercise 1v program:
-- Exercise 1v: A 4-Bit Binary to 7-Segment Decoder
ENTITY Ex1v IS
PORT (
END Ex1v;
ARCHITECTURE max OF Ex1v IS
BEGIN
SS <= 2#111_1110# WHEN bn = 0 ELSE -- Binary, Decimal
2#011_0000# WHEN bn = 1 ELSE
2#110_1101# WHEN bn = 2 ELSE
2#111_1001# WHEN bn = 3 ELSE
2#011_0011# WHEN bn = 4 ELSE
2#101_1011# WHEN bn = 5 ELSE
2#101_1111# WHEN bn = 6 ELSE
2#111_0000# WHEN bn = 7 ELSE
2#111_1111# WHEN bn = 8 ELSE
2#111_1011# WHEN bn = 9 ELSE
2#111_0111# WHEN bn = 10 ELSE
2#001_1111# WHEN bn = 11 ELSE
2#100_1110# WHEN bn = 16#C# ELSE -- Binary, Hexadecimal
2#011_1101# WHEN bn = 16#D# ELSE
2#100_1111# WHEN bn = 16#E# ELSE
2#100_0111# WHEN bn = 16#F#;
END;
Adding the folder: Options -> User Libraries... -> ..\ex1v (folder containing exercise 1v files) -> Add -> OK
I highly suggest getting a newer dev kit. You can get the cheapest from altera for $50 and you will be able to use the most recent version of quartus. I highly suggest ditching what you have. You're not really learning anything.
