17267 Discussions
exporting data out of modelsim
Is there a way to get all the data from one wave in the wave window of modelsim exported to a text file?
Maybe this will help: http://www.csee.umbc.edu/portal/help/vhdl/textio.vhdl
Or You need somehow other type of output?
Thank you for the reply.
As I look at the code I am guessing this writes inputs and outputs to a test file. I'm going to have to sit down with this one.
Is there a way to create this sort of output in Modelsim and leave the VHDL code alone?
Thanks again
Bill
--- Quote Start ---
--- Quote End ---
Modelsim does have alternative views than the wave window. Looks like the list window can be used to do what you want:
http://www.velocityreviews.com/forums/t23392-exporting-data-in-modelsim.html
Cheers,
Dave
Perfect ! Thanks!!!
