17255 Discussions
fixing missing links between files
Q7.2 web
How do I restore links between projects and files once everything is created?
I am somehow losing the links between the bdf, the bsf it contains, and the underlying hdl for the bsf.
What I usu do is create a new project, then create a .v file and create a bsf for that file. Then I create a bdf and place the symbol on it, and make it the top level entity. I add the bdf and the .v file to the project in the file settings dialog.
Somewhere in this process links are lost since when I double click on the symbol, nothing happens. I can then remove the files from the project (settings dialog) and then do 'add all'. The link between the symbol and the .v file seems to be restored, yet when I compile I get 'Top partition does not contain any logic'.
What step is missing here?
After doing what seemed like the same steps (deleting and recreating bsfs and bdfs, setting project top, removing and re-adding files, cursing...) over a few times, I was able to get by the previous issue. All I can figure is some file must have been out-of-date.
More mysteries awaiting solutions:
I have been working with a project that has two parts; the nios part of the project sits in the main project folder along with its bdf and associated files. One of the symbols on this top bdf refers to a large chunk of logic whose files I keep in a sub-folder (including its own bsf and bdf). I don't want to just plop these files all in the main folder. Quartus does not like this at all, and will only compile successfully if I delete the db folder before every compile (sometimes not even then).
In the project settings->files I have tried:
1 Just including the files in the main folder
2 Explicitly including all the files in both the main and sub folder
3 Doing# 1 and also the bdf in the sub-folder
4 Including the sub-folder as a library name only (is this correct?)
Although each one of these methods can work at times, it is not foolproof.
Option# 4 has been the most reliable as long as I delete the db folder every-single-time.
If there is a way to avoid this annoyance I'd love to hear it.
Another mystery behavior:
A compile that normally takes 30min will complete 'successfully' in 2min, yet only use 1% resources. How can it be successful if it has ignored most of the design?
Here I found I had to go back into SOPC and re-generate the system. I had not made any changes in SOPC, but I had been walking thru the SOPC dialogs to check settings. This seems to be enough to corrupt the database and require re-generation. As long as I know about this behavior I can live with it.
Another mystery:
SOPC shows a small red triangle next to one of my component base addresses. Why?
Another mystery:
The hierarchy tab for my project was not expandable. Once again this is the I-don't-see-your-project-files problem. I had to delete all the files in settings->files and re-add them.
Another mystery:
Adding all the project files in settings->files will lead to a compile error "file pllpll.....bb.v declared/included more than once...". This is a file(s) created by the pll wizard but I have to remove it from my project files settings. Is this normal? Why is it created if it shouldn't be used?
