17261 Discussions
floating point in verilog question
Hi there,
I'm converting some code in DSP floating point to systemverilog. I always get value 0 instead of 0.00001 in TI DSP. Is there a library to support floating point in Quartus device?
Thanks and have a good weekend.
Sean
you have a couple of options
Altera has some floating point megafunctions, i think Verilog is supported:
http://www.altera.com/literature/ug/ug_altfp_mfug.pdf
DSP Builder Advanced Blockset has some floating point blocks and full "math.h" support. it generates VHDL:
http://www.altera.com/literature/hb/dspb/hb_dspb_adv.pdf
you could also try the VHDL 2008 floating point package (there are some modified for VHDL-93 out there). this is not optimized for/by Altera, so i would expect the lowest fmax and highest resource usage out of the 3
or you can try and convert it all to fixed point :)
Thanks pancake,
I already looked into megacore ip and I don't know where to start. Do you have any samples to let me fresh start.
In C code.
float scale_factor;
scale_factor = 1 / (float) number_of_samples;
Is there module .v that I just plug the float value in/out?
Thanks, I will look over the weekend.
Sean
