17268 Discussions
frequency meter on cyclone IV E ,without display frequency
hi everybody.
sorry for my english.
I ask for your help for released an simple frequency meter with vhdl (i am newbie on FPGA):
https://alteraforum.com/forum/attachment.php?attachmentid=14027&stc=1
Input
"ref_clock" is 50 MHz periode 20ns of cyclone IV E.
"signal" is mesured signal from encoder
Output
cycle of test errors every 1 sec
if frequency >= 1000 Hz ==>error1 = 1 //1 is logic HIGH
if frequency >= 2000 Hz ==> error1 = 1 and error2 = 1
else error1 = 0 and error2 = 0 //0 is logic LOW
thank you.
What help do you need. What problems are you having?
try google: fpga vhdl frequency measure
(hint: the second hit may be this one: http://surf-vhdl.com/compute-frequency-clock/)
thank you Tricky, josyb.
Tricky, how to do it in the simplest way possible.
josyb, I didn't understand half of the code.
I told you that I was newbie in(FPGA VHDL...)
Here is my code
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity freq_meter is port ( i_ref_clock : in std_logic; -- 50 MHz i_signal : in std_logic; -- from encoder o_error1 : out std_logic; o_error2 : out std_logic); end freq_meter; architecture freq_meter_arch of freq_meter is begin -- CLOCK REFERENCE domain variable clock_secand_decounter : integer := 50000000; variable i_signal_counter : integer := 0; if(clock_secand_decounter<=1) then if(rising_edge(i_signal)) then i_signal_counter <=i_signal_counter+1; if(rising_edge(i_ref_clock)) then clock_secand_decounter <= clock_sec_dec -1; end if; end if; end if; if(clock_secand_decounter >= 1000)then o_error1='1'; o_error2='0'; elsif(clock_secand_decounter >= 2000)then o_error1='1'; o_error2='1'; else o_error1='0'; o_error2='0'; end if; end freq_meter_arch;
Yes I know there is a lot of errors
Here is the timeline.
https://www.alteraforum.com/forum/attachment.php?attachmentid=14030
The syntax errors should be easy enough for you to fix by referencing a vhdl text book.
But there are more fundamental errors - eg. Having a rising edge inside a rising edge will never occur in reality. I suggest you work through a tutorial that covers basic logic to try and understand what is wrong with your code.
ok.
Tricky, thanks for the advice.
