17255 Discussions
generate with step other than unit
I need to write a GENERATE statement, but the step must be different from unit.
Something like:
gen: for i in 0 to 20 generate temp(i) <= temp(i+4-2) or temp(i+4-1); end generate;
this "i" must be incremented by 4 units instead of 1.
Jaraqui
with something like this:
gen: for i in 0 to 4 generate
temp(i) <= temp(i * 4 +4-2) or temp(i * 4+4-1);
end generate;
but check the range of i.
--- Quote Start ---
end generate;
--- Quote End ---
thank you! I will test this solution, but I need only temp(0), temp(4), temp(8), ... be the positions to receive assignments.
Writing in this way, I suspect that temp(0), temp(1), temp(2), ... would receive assignments
Jaraqui
You're right. The new code would be:
temp(i * 4) <= temp(...
I found another thread about this.
http://www.alteraforum.com/forum/showthread.php?t=25890
Sorry for my poor previous query.
What I was exactly looking for is a "programmable step" and not a step that has to stablish some logic between the index and my desired positions.
Something like
for i in begin to end loop (step n) generate...
Reading about this I seems that this feature isn´t availabe for concurrent generate as well as for sequential loops...
Is that correct?
Jaraqui
To learn about allowed VHDL constructs I suggest to read a text book or the LRM.
In the present case, these points should be considered:
- the range of sequential for loops as well as generate loops must be constant.
- you can achieve a variable range or a variable step size in sequential for loops by combining it with conditional statements
- this is impossible with generate statements by their nature
