Hi there! I have an odd problem. I have to implement in VHDL a Demultiplexor 1:8, using guarded blocks. When I simulate in Active-HDL it's seems that all of the guard conditions are true so it doesn't works like a demultiplexor. here is the code:
-------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.all; entity demux is port (entry,s1,s2,s3:in bit; y: out bit_vector (7 downto 0)); end demux; ------------------------------------- architecture arch of demux is begin out0:block ( s1='0' and s2='0' and s3='0' ) begin Y(0)<=entry; end block; out1:block ( s1='1' and s2='0' and s3='0' ) begin Y(1)<=entry; end block; out2:block ( s1='0' and s2='1' and s3='0' ) begin Y(2)<=entry; end block; out3:block ( s1='1' and s2='1' and s3='0' ) begin Y(3)<=entry; end block; out4:block ( s1='0' and s2='0' and s3='1' ) begin Y(4)<=entry; end block; out5:block ( s1='1' and s2='0' and s3='1' ) begin Y(5)<=entry; end block; out6:block ( s1='0' and s2='1' and s3='1' ) begin Y(6)<=entry; end block; out7:block ( s1='1' and s2='1' and s3='1' ) begin Y(7)<=entry; end block; end arch; --------------------------------- please run it. Thank you!Link Copied
When you say you have to use guarded blocks, do you really have to? Its something that I have never ever used, and never ever seen used. Even in my doulos golden reference guide (which I, and many others, use as my most important VHDL reference) says
--- Quote Start --- Synthesis: "Most commercial synthesis tools do not support blocks. Use processes instead" Tips: "It is not necessary to learn and use blocks and related syntax suych as guarded signal assignments. It is generally more efficent for simulation to use processes instead." --- Quote End --- From what I understand from my reference, and looking at your code, you should be writing: Y(N) <= guarded entry; But I am probably wrong, and I dont think you'll be able to get much help on this forum.- Mark as New
Thank you. I'm at the begining and your replay was very useful. I will read The VHDL Golder Reference Guide!
The Doulos golden reference guide is really for those already familiar with VHDL. You need a good VHDL tutorial.
Where did you learn how to use blocks?- Mark as New
I'm studying at the university. I wanted to use blocks because in our laboratory guide is an exercise that says:"Make a demultiplexer 1 to 8 using logic gates and for every logic gate use a block"(in my opinion it's a primitive way to make a demultiplexer in VHDL). Anyway, the point is that even if I've made a demultiplexer weeks ago using a process, I want to understand more of the concurrent domain, soo I'm testing stuff. I find the golden reference guide very useful and much more practical than our laboratory guide
