help with counter
im trying to learn to create counter that starts counting based on the input that from the expansion after i compile it it seems an error occur and i dont know how to solve it. help me guys.. this error occured (Error (10500): VHDL syntax error at ledwithcounter.vhd(29) near text "then"; expecting ":=", or "<=") ....here i attach my program.. help me guys..
Library IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_unsigned.all;
entity GPIOwithLED is
port( GPIO_0 : in std_logic_vector(1 downto 0);
ld_enb : in std_logic;--parallel load enable,active high
clk : in std_logic;-- system clock
cnt_enb : in std_logic;--count enable, active high
rst_n : in std_logic;-- reset,active high
q : out std_logic_vector(1 downto 0));
end GPIOwithLED ;
architecture bufferwithGpio_arc of GPIOwithLED is
begin
process(GPIO_0)
begin
if (GPIO_0(0)='1') then q<=GPIO_0(1 downto 0);
else q<= "00";
end if;
end process;
counter:process(clk,rst_n) is
begin
if ( rst_n='0' ) then
count <=(others=>'0');
else(clk'event and Clk ='1')then
if (ld_enb='1')then
count<=GPIO_0;
elsif(cnt_enb ='1')then
count <=count+1;
end if;
end if;
end process counter;
-- assigment ouput
q <= count;
end bufferwithGpio_arc;
--- Quote Start ---
--- Quote End ---
remove the is
--- Quote Start ---
begin
--- Quote End ---
use elsif
Finally you cannot assign to q twice(multiple drivers)
library ieee;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity ledwithcounter is
cnt_out : out std_logic_vector(1 downto 0);
end ledwithcounter ;
architecture bufferwithGpio_arc of ledwithcounter is
begin
process(GPIO_0)
begin
else q<= "00";
end if;
end process;
begin
elsif(clk'event and Clk ='1')then
if (ld_enb='1')then
count<=GPIO_0;
count <=count+1;
end if;
end if;
-- assigment ouput
cnt_out <= count;
i have already done what u have said and now a problem oocurs.. Error (10482): VHDL error at ledwithcounter.vhd(31): object "count" is used but not declared.. how does i elminted this error..
--- Quote Start ---
library ieee;
begin
process(GPIO_0)
begin
else q<= "00";
end if;
end process;
begin
if (ld_enb='1')then
count<=GPIO_0;
count <=count+1;
end if;
end if;
-- assigment ouput
cnt_out <= count;
--- Quote End ---
You need to declare it after architecture keyword to be known e.g.
signal count : std_logic_vector(1 downto 0) := "00"; -- just like ports but without in/out
or you better declare it as
signal count: unsigned(1 downto 0) := "00";
in this case you need to add final assignment to count_out as a cast :
cnt_out <= std_logic_vector(count);
finally use numeric_std library instead of signed/unsigned libraries.
library ieee;
use ieee.numeric_std.all;
begin
process(GPIO_0)
begin
else q<= "00";
end if;
end process;
architecture rtl of counterun is
begin
-- Local signal because it has to be read internally
-- unsigned type used because of "+" operation needed
begin -- architecture rtl
begin
if (ld_enb='1')then
count<=GPIO_0;
count <=count+1;
end if;
end if;
-- assigment ouput
end architecture rtl;
i have follow all of your instruction.but stil there is error occur.Error (10500): VHDL syntax error at ledwithcounter.vhd(31) near text "signal"; expecting "end", or "(", or an identifier ("signal" is a reserved keyword), or a concurrent statement....
do i need to declare the port of my counter in separate ways from my input port. need clarifaication sir..
use one architecture
also don't need library std_logic_arith
i have already done that now thiss error occur
Error (10327): VHDL error at ledwithcounter.vhd(35): can't determine definition of operator ""+"" -- found 0 possible definitions
--- Quote Start ---
--- Quote End ---
where is your code?
ibrary ieee;
begin
process(GPIO_0)
begin
else q<= "00";
end if;
end process;
begin
if (ld_enb='1')then
count<=GPIO_0;
count <=count+1;
end if;
end if;
end process;
need to include the arith library then theres is no error. but it shows 9 warning..is that okey mr kaz
declare count as unsigned.
if the following is rejected then cast it:
count <= unsigned(GPIO_0);
mr kaz
silly question from me.. the code works..but i would like to try this code using my alterra de2 board by using the pin assignment.. as for the input i simply connect it to my PIR sensors and the output will be my LED. so for the clock should use the 50Mhz internal clk and pushbutton for my rst_n.is that correct or not. ade how does i set for my cnt_enb and ld_enb.
I don't know what your plans are but sounds ok to me to use a 50MHz clock and manual pushbutton reset as long as it is suitable to your case!! Try and learn. All of us play with code until it works. If it doesn't you are in trouble.
tq mr kaz..
sorry for troubling you.
Help with counter
library ieee;
entity AcounterGpio2 is
port( PIRin : in std_logic;
clk : in std_logic;
reset : in std_logic;
PIRout : out std_logic;
q : out std_logic);
end AcounterGpio2 ;
architecture bufferwithGpio_arc of AcounterGpio2 is
signal cnt,enable: std_logic;
begin
process(PIRin)
begin
if PIRin = '1' then
PIRout <= PIRin ;
else PIRout <= '0';
end if;
end process;
counter:process (clk)
enable <= PIRout;
begin
if (rising_edge(clk)) then
if reset = '1' then
cnt := 0;-- Reset the counter to 0
elsif enable = '1' then
cnt := cnt + 1;-- Increment the counter if counting is enabled
end if;
end if;
-- Output the current count
q <= cnt;
error Error (10500): VHDL syntax error at AcounterGpio2.vhd(29) near text "enable"; expecting "begin", or a declaration statement keep showing up.. what should i do and how do i declare the output from PIRout that will be the input for my counter.
First get rid of the ieee.std_logic_unsigned.all; and use unsigned and signed types, as suggested before. Second you can to signal assignments just after the process line. it needs to be after the "begin".
