My project is: design and test 4X4 bit unsigned multiplier using right shift add algorithm
With little knowledge about VHDL One friend Kaz has helped me write the code.but I dont understand completely. Can you explain it to me? here is the code that I get troubles: architecture rtl of mult1 is signal shift_reg1 : std_logic_vector(3 downto 0) := "0000"; signal shift_reg2 : std_logic_vector(7 downto 0) := x"00"; signal reg1 : std_logic_vector(7 downto 0); signal opA : std_logic_vector(3 downto 0); begin R <= shift_reg2(0); reg1(7 downto 3) <= std_logic_vector(resize(unsigned(OpA),5) + unsigned(shift_reg2(7 downto 4))); reg1(2 downto 0) <= shift_reg2(3 downto 1); what's the three signals shift-reg1,shift-reg2,reg1( they are the singals between?) what does shift-reg2(0) mean? Is it nessecary to write :="0000" and :=x"00" at the signal shift-reg1,2 (My teacher dont write them in the signal declaration) and the next code I almost don't understand ( other ways to write them easier to understand??). I have added the diagram of the algorithm and the whole code( helped by Kaz) underneath. Looking forward to hearing from you soon.;)Link Copied
--- Quote Start --- architecture rtl of mult1 is signal shift_reg1 : std_logic_vector(3 downto 0) := "0000"; signal shift_reg2 : std_logic_vector(7 downto 0) := x"00"; signal reg1 : std_logic_vector(7 downto 0); signal opA : std_logic_vector(3 downto 0); begin R <= shift_reg2(0); reg1(7 downto 3) <= std_logic_vector(resize(unsigned(OpA),5) + unsigned(shift_reg2(7 downto 4))); reg1(2 downto 0) <= shift_reg2(3 downto 1); what's the three signals shift-reg1,shift-reg2,reg1( they are the singals between?) --- Quote End --- shift_reg1 corresponds to your 4 bit shift reg of multiplier. shift_reg2 is your second 8 bit register right at product output. reg1 is the other 8 bit register at top of your diagram --- Quote Start --- what does shift-reg2(0) mean? --- Quote End --- 1st lsb of that register i.e. bit index 0 --- Quote Start --- Is it nessecary to write :="0000" and :=x"00" at the signal shift-reg1,2 --- Quote End --- no, but if you go to modelsim you will get some undefined initial values. --- Quote Start --- and the next code I almost don't understand ( other ways to write them easier to understand??). --- Quote End --- you can use an adder directly instead of addition statement. go to megawizard(tools menu) and let quartus create an adder then you need to connect as 4 bits , 4 bits inputs and 5 bits output. the shifting itself can be done through megawizard as well.
