can some onehelp me????
hi everyone .Im a 21 year old girl from Vietnam. i have a project and have to submit it to my teacher on the 20th of May . Can you guys here help me with this project.
I would really appriciate your help^^^
the project is: design and test 4X4 bit unsigned multiplier using right shift add algorithm.
I have difficluties in describing the two registers. Can you help me write it in VHDL code? thanks very much!!!
I have attached the diagram bellow..
Hope to get nice reply from you soon:)
thanks in advance^^^
have you written any code yet? If you havent - I would get started
dear friend Tricky !
first of all, thanks for your relpy.
I have written the code for : mux( 4 bit), adder(4 bit)(it's easier than the rest).Can you help me with : 1 bit right shift-reg, and the 8 bit two registers.
I understand right shift add algorithm however have difficulties in describing them in VHDL.
here is my logic( hope it will help you a little bit):
first: the shift- reg: it has 2 inputs and one output. after 1 clk it performs 1 bit right shift .
second: the 4 bit MUx: it has 3 inputs,1 output.let's call opc is the signal between the MUx and shift-reg: if opc=1 then opa=multiplicand otherwise opa=0.
third:the 4 bit adder: 2 inputs(opa,opb) and 2 outputs(cout,sum).
finally is the 8 bit 2registers. i get troubles with them.
Is my understand right?
with little knowledge about VHDL. Hope you can help me as much as possible!!!!
I have attched one example (word file:23.5k) bellow
expect to here from you soon friend:-P^^
If it helps, I know of another algorithm for multiplication using right shift.
you add A + B as follows:
1) if register(0) = '1' then add "B"&"0000" to "0000"&A (8 bit register)
2) right shift reg result
repreat above 4 times. take result from shift reg. thats all
here is the code, checked quickly but not tested well
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity mult1 is port( load : in std_logic; clk : in std_logic; A : in std_logic_vector(3 downto 0); B : in std_logic_vector(3 downto 0); ready : out std_logic; R : out std_logic_vector(7 downto 0) ); end entity; architecture rtl of mult1 is signal shift_reg : std_logic_vector(7 downto 0) := x"00"; signal count : integer range 0 to 8 := 0; begin process(load,clk) begin if load = '1' then ready <= '0'; count <= 0; shift_reg <= "0000" & A; elsif rising_edge(clk) then if count < 8 then count <= count + 1; end if; if count = 8 then R <= shift_reg; ready <= '1'; end if; case count is when 0 | 2 | 4 | 6 => if shift_reg(0) = '1' then shift_reg <= std_logic_vector(unsigned(shift_reg) + unsigned(B&"0000")); end if; when 1 |3 | 5 | 7 => shift_reg <= '0' & shift_reg(7 downto 1); when others => null; end case; end if; end process; end rtl;
thanks very much for your help. I need a little time to undertand if it works out for my project.
really appreciate!!!:p
I just noted a bug i it.
It works up to 15 x 8 = 120
if B is more than 8 it breaks, so needs some debugging if you want to adopt this approach. It is based on old logic of the 70s
sorry Kaz.Can you write the algorithm as I have explained above(like in the diagram).bcoz the code must be written in steps that involve components such as : 1 bit shift-reg, Mux(4 bit), adder(4 bit),and the 8 bit registers. Any other solutions? thanks:p
Just to debugg my code, the error was due to adder overflow. So I added one more bit. see coe below.
Meanwhile, I will look at your algorithm and see if I can go further.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity mult1 is port( load : in std_logic; clk : in std_logic; A : in std_logic_vector(3 downto 0); B : in std_logic_vector(3 downto 0); ready : out std_logic; R : out std_logic_vector(7 downto 0) ); end entity; architecture rtl of mult1 is signal shift_reg : std_logic_vector(8 downto 0) := '0'&x"00"; signal count : integer range 0 to 8 := 0; begin process(load,clk) begin if load = '1' then ready <= '0'; count <= 0; shift_reg <= '0'& "0000" & A; elsif rising_edge(clk) then if count < 8 then count <= count + 1; end if; if count = 8 then R <= shift_reg(7 downto 0); ready <= '1'; end if; case count is when 0 | 2 | 4 | 6 => if shift_reg(0) = '1' then shift_reg <= std_logic_vector(unsigned(shift_reg) + unsigned(B&"0000")); end if; when 1 |3 | 5 | 7 => shift_reg <= '0' & shift_reg(8 downto 1); when others => null; end case; end if; end process; end rtl;
I now strongly believe, your algorithm is same as mine. In my case I do all in the shift register with no intermediate containers.
The mux is the test I do on regiser bit(0). The last bit I added was the carry bit.
thanks for your useful help kaz. Im third year student from Vietnam and now is 6 pm it's time for dinner. Tonight I will try your method and to understand it thorouly.
if I need your help again. Would you pleased to help me?
see you tomorrow at the same time.ok.:-P
I will try but tomorrow this time I will be at work and don't want to upset my boss. I will try today to see if I can really understand and then implement your version as it is blockwise. Enjoy your dinner...
hi Kaz . iam just back.
oh. tomorrow is monday.(i forgot). thanks for your enthusiam.
again,many thanks to you.
best wishes!
I played a bit with your algorithm and realised your output is serial.
Here is the code that corresponds to your algorithm. It worked as far as I tested but check various values of the range 0_15 on both A,B inputs.
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity mult1 is port( load : in std_logic; clk : in std_logic; A : in std_logic_vector(3 downto 0); B : in std_logic_vector(3 downto 0); ready : out std_logic; R : out std_logic ); end entity; architecture rtl of mult1 is signal shift_reg1 : std_logic_vector(3 downto 0) := "0000"; signal shift_reg2 : std_logic_vector(7 downto 0) := x"00"; signal reg1 : std_logic_vector(7 downto 0); signal opA : std_logic_vector(3 downto 0); signal count : integer range 0 to 7 := 0; begin R <= shift_reg2(0); ready <= '1' when count = 5 else '0'; reg1(7 downto 3) <= std_logic_vector(resize(unsigned(OpA),5) + unsigned(shift_reg2(7 downto 4))); reg1(2 downto 0) <= shift_reg2(3 downto 1); process(load,clk) begin if load = '1' then count <= 0; shift_reg1 <= A; -- load input A into shift register elsif rising_edge(clk) then if count < 7 then count <= count + 1; end if; shift_reg1 <= '0' & shift_reg1(3 downto 1); -- shift right shift_reg2 <= reg1; if shift_reg1(0) = '1' then OpA <= B; else OpA <= "0000"; end if; end if; end process; end rtl;
wow! Kaz ,im grateful to you for being so kind to me.I still have 5 days before having to submit my project to my teacher . tomorrow afternoon , I have a test ahead so have to spend time for it. Dont have enough time studying my project right now.
The code you have just posted seems suitable for my algorithm.
I will examine it in the next few days.
Hope you will be pleased to continue...help....
it's 11pm and I should go to sleep now.
Happy to have a chat with you friend Kaz ;)
hey Kaz do you have time?
i have difficulties understand your code.
yes plenty of time. which part of code is the difficult?
begin
R <= shift_reg2(0);
what's the three signals shift-reg1,shift-reg2,reg1( they are the singals between?) what does shift-reg2(0) mean?
Is it nessecary to write :="0000" and :=x"00" at the signal shift-reg1,2
(My teacher dont write them in the signal declaration)
and the next code I almost don't understand ( other ways to write them easier to understand??).
Im not very good at VHdl so the question I asked you seem a little '' stupid" .Hope you won;t despise me........
thanks very much!!!!!!!!!!!
