17268 Discussions
hi! Understanding a coding (counter), help
entity counter is
generic (
n : natural := 4;
port (
clock : in std_logic;
reset_n : in std_logic;
q : out std_logic_vector(n-1 downto 0)
end entity;
architecture rtl of counter is
signal value : std_logic_vector(n-1 downto 0);
begin
process(clock, reset_n)
begin
if (reset_n = ’0’) then
value <= (others => ’0’);
elsif ((clock’event) and (clock = ’1’)) then
value <= value + 1;
end if;
end process;
q <= value;
end rtl;
What would you like to know?
This is a very simple piece of code:
First the Entity "counter" is declared with a Generic "n" (Kind of Parameter used for the Instance-Generating) and three Ports "clock", "reset_n" and the only Output "Q" whith the variable width of "n".
Then the Architecture:
There is one Signal "value" (Wire for Verilog-Programmers) also with the variable width of "n".
The PROCESS:
The Process listenes to "clock" and "restet_n": If "reset_n" is '0' then all bits of "value" are cleared to '0'.
If "reset_n" is not '0', then value is counted up by one if there is a rising edge on "clock".
The setting of the Output:
The Output "Q" is set to the value of "value" asynchronously.
You can also do the staight way and increment "Q" in the Process, but it is recommended not to use Outputs in a Process because you can not read from them.
For Example if you increment "value" you can use this Signal in another Process and read it out. If you increment "Q" instead, you cannot read "Q" in another Process because Output-Ports are not readable.
It appears to be a non-standard counter (unless it's VHDL 2008). But you missed out the library inclusions, so would not compile at all.
thanks!!
and for example, an 8-bit counter can be specied as??
eight bit:counter
generic map( n => 8 )
port map eight bit ( clock , resetn , Q) ;
i want create a modulo-k counter by modifying the design of an 8-bit counter to
contain an additional parameter, the counter should count from 0 to k-1 and when the counter reaches the value k -1 the value that follows should be
0.
I'm interested create a modulo-k counter by modifying the design of an 8-bit counter to
yes:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
If you want to count to "k-1", you should replace:
value <= value + 1;
by something like:
if (value < k) then value <= value + 1; else value <= (others => '0'); end if;
And then you have two choices:
Do you want to have "k" hard coded in your design then you can make a new generic with
k : integer :=32;
Where 32 is only a pre-defined Value for k and can be replaced by the parent entity.
Or for changing the Value while the Core runs, you can define a new port as Input:
k : in unsigned (15 downto 0 );
Where 15 is the maximum width of the Input (actually 16Bit).
ok, I get it, thanks again!!
but; define a new port as Input, i have to delete Q or other port?;
entity counter is
generic (
n : natural := 4;
port (
k: in unsigned (15 downto 0);
end entity;
architecture rtl ofcounter issignal value : std_logic_vector(n-1 downto 0);
begin
beginif (reset_n = ’0’) then
if (value < k) then
value <= value + 1;
else
end if;
end process;
q <= value;
end rtl;
No, you do NOT have to delete an other port.
Just add the new port in the port-list.
BUT: Every entry in the Port-list ends with a semicolon except the last one.
So the correct port list would be:
port ( clock : in STD_LOGIC; reset_n : in STD_LOGIC; Q : out STD_LOGIC_VECTOR(n-1 downto 0); k: in unsigned (15 downto 0) );
PS: Please use the CODE-Braces to write Code in the Forum. It makes Reading a bit easier. (See advanced Posts)
hi!!
I have written:
library ieee;
use ieee.std_logic_unsigned.all;
entity counter is
generic (
n : integer := 4;
k : integer := 8
port
SW: in std_logic_vector(7 downto 0);
KEY : in std_logic_vector(1 downto 0);
LEDR : out std_logic_vector(7 downto 0)
end counter;
signal Q_int: std_logic_vector(n-1 downto 0);
begin
PROCESS(clock, reset_n)
begin
if (reset_n = '0') then
Q_int<= (others => '0');
elsif ((clock'event) and (clock = '1')) then
if Q_int>= k-1 then
else
Q_int <= Q_int + 1;
end if;
end if;
end process;
Q <= Q_int;
end rtl;
architecture Behavioral of counter is
component counter
generic
n : integer := 4;
k : integer := 8
end component;
begin
eight_bit: counter
generic map ( n => 8, k => 4)
port map eight_bit( clock, reset_n, Q, KEY(1), KEY(0), LEDR );
end Behavioral;
is correct?? exactly I want to write:
Create a modulo-k counter by modifying the design of an 8-bit counter to
contain an additional parameter. The counter should count from 0 to k-1.
When the counter reaches the value k-1 the value that follows should be 0.
Your circuit should use pushbutton KEY0 as an asynchronous reset, KEY1 as
a manual clock input. The contents of the counter should be displayed on red
LEDs. Compile your design with Quartus II software, download your design
onto a DE1 board, and test its operation. Perform the following steps:
-Create a new Quartus II project which will be used to implement the
desired circuit on the DE1 board.
It sounds like a homework assignment. It looks like code to me - why not try writing a testbench and simulating it?
Apparently you want to create a hierarchical design by instantiating the component counter in a top entity. But you don't write a separate entity, instead a second architecture inside the entity counter. This doesn't work.
Hi, On the 2nd part your are *completely* wrong : you can't use the same entity in the description of THIS entity, It is equivalent to saying "A car is made with a car",
I recommand port mapping by names, not by position, some thing like this
my_counter : entity counter generic map ( n => 8, k => 4) port map ( clock => KEY(1), reset_n => KEY(0), Q => Q_int, SW => ???, KEY => ???, LEDR => ??? ); LEDR <= Q_int;
I think that you only have to modify the "rtl" architecture, that what you have done.
HI!! help please...Why it gives me this error? I want to put a function of k n
library ieee;
use ieee.numeric_std.all;
entity contador is
generic (
k : natural:= 8;
n : natural:= LOG2(k+1)--> error (10482): vhdl error at contador.vhd(12): object "log2" is used but not declared
port
clock: in std_logic;
reset_n: in std_logic;
Q : out std_logic_vector (n-1 downto 0)
end contador;
architecture rtl of contador is
signal clock,reset_n: std_logic;
begin
begin
if (Q_int<k) then
Q_int <= Q_int + 1;
else
end if;
end if;
end process;
Q <= Q_int;
end rtl;
You have no log2 function included - you will need to write one and add it to a package. You will also struggle because you cannot use other generics inside the generic region
moreover the generic 'k' is not used here. So you can delete it.
(and give to 'n' the number of bits.)
