17255 Discussions
how can I drive an array from a component to the top level
hello everyone!!!:)
I have a question related to my design,
my design: top_level---->
----------------------------->component :registers
----------------------------->component :cpu
I have a component called "registers" that has lots of registers (120 registers 8bit each).
In this case I can declare an Array inside this component.
my quaestion is:
can I drive it out of this component("registers") to the top_level of my design?
I was trying to do that with no success, can you assist?
ENTITY registers IS
PORT (
my_array out -- .....??
END;
You will need to declare the array type in a package that is used in the top level entity and the registers component. Then they have a common view of the types.
