17252 Discussions
how to change modelsim's default file browser.
BHerr6
Hello, I have been trying to get modelsim to work on my linux computer, but the modelsim is laggy and the fonts won't display correctly.
I'm using a Debian based distro. I wonder if there is any way to change this file browser to something else. Or if there is a way to fix this.
Nurina
Did you try reinstalling ModelSim; you might have gone through a bad installation.
Otherwise can you let me know the following:
  1. Does this problem only occur when File Manager is involved?
  2. Which version of ModelSim are you using?
Nurina
BHerr6
Hi, This issue only occurs with the File Manager. I'm using this version of Modelsim.
Even tho I can't see the font on the files. If I click on one of the folder, it refreshes and show the name for that folder. It's a weird bug tbh.
I'm having issues only with the file manager.
I also tried changing the color scheme of my computer and the color scheme of Modelsim. But it didn't help.
Nurina
I'll report this problem to engineering. Can you let me know which OS you are using?
Nurina
BHerr6
My OS is parrot OS, a Debian based OS.
Nurina
Can you also let me know which file manager used in modelsim? Also what CPU are you using?
Nurina
BHerr6
I'm sorry for the late reply. I don't know which file manager is being used on Modelsim, but it seems to be embedded into the program, I see no child process being open by Modelsim when opening the file manager. My CPU is a Intel i7 10750H 6 Cores, 12 Threads. The device that I'm using is GS66 Stealth 10SF REV:1.0 with a Debian based distro, Parrot OS. I always had issues with Modelsim even in Arch Linux.
Nurina
The root cause for your problem is ModelSim Intel FPGA does not support your current OS: https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html?elq_cid=7511234_ts1624241179952&erpm_id=10446625_ts1624241179952
Unfortunately you're going to have to live with that issue. This is not something engineering can fix since you use an unsupported OS. A possible workaround would be to use a remote desktop with a supported OS.
Apologies on the inconvenience.
Nurina
Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
