17259 Discussions
how to create matrix in VHDL
Hi guys! I am trying to create a matrix or an array. 4 columns and 2 rows. Is my code correct?
type row_t is array(0 to 3) of std_logic_vector(7 downto 0); type matrix_t is array(0 to 1, 0 to 3) of std_logic_vector(7 downto 0);
Also I want to assign a variable to the first column? what is the syntax for this? thank you.
Yes, it is a matrix
2d matrices cannot be slices, so you need to assign individual elements.
You could build it with 1d arrays, which can be sliced to apply an entire row.
what is the syntax for slicing a row?
like this (not possible with 2d array:
op <= matrix(a to b);
or
op <= matrix(b downto a);
You really need to try some code yourself - this is very basic VHDL fundamentals you should be learning yourself from a book or from a tutorial.
--- Quote Start ---
Yes, it is a matrix
--- Quote End ---
Excuse me for being pedantic but the OP asked how to assign a variable to the first column. Which is as tedious for a 1Dx1D as for a 2D array?
