17249 Discussions
how to create the *.sof file for programmer?
The previous old version outputs a default *pof, *sof files for programmer,
but after installation of 13.0, the pof, sof is not there as default setting.
,even compilation was correctly done.
Can someone point me the settings for those output files?
Vraifluss
That is strange, it should be there with the default installation. This may sound elementary, but when you pull up the programmer, are you selecting JTAG? Otherwise the file selctor won't even look for *.sof.
Not much help, I've never seen this before.
Have you tried searching in the output_files folder instead of the main folder?
HI
created a simple test code and compiled it completely, but no *.sof, *.pof files generated in project directory and output files directory.
It seems that my setting is wrong? do you know what I should set for these output?
Is this license issue ? using qurtus2 web edition v13.0.
Vraifluss
13.0 was not , but 14.0 can create the *.sof. Still do not know why??
Anyway I can use 14.0 web edition.
Vraifluss
